http://pcpartpicker.com/p/1t0Ds
Threw together this build for right around 900$ with compoents, question is will the 6300 bottleneck the 770?
Heard that the term bottlenecking is thrown around loosely so i came here to figure it out
Im pretty certain it will. Switch the cpu to an FX-8320 or 8350 or an i5 3570k and j wont bottleneck for sure.
You can save a couple of bucks by getting an 8320 and overclock it to a 8350's specs and get a graphics card that is a bit better than a 7950.
http://pcpartpicker.com/user/Killerfrenzy96/saved/2c3T
