Hi as you can tell I have no posts here (made a new account, forgot old password+email >_< ) but Ive been following Logan and the rest of the Tek Synd crew for 2 years now, so hopefully I know a bit about PCs. Anyway, onto the build, I'm willing to spend £900-1000 with a stretch of £100 (Sorry about the UK prices, wish I was in the US, where parts are so much cheaper >:( ). Anyway, thanks in advance if you do help.
Budget: £900-1000
Where: UK
Currency: GBP (£)
Aria, Scan, Overclockers.co.uk, Dabs or any other UK retailer that comes up on partpicker.
Peripherals: I need a new mouse (got my eye on the Deathadder) (I'm right-handed so non-left and non-ambi would be appreciated), Keyboard (nothing fancy, looking at the £4.99 OcUK Budget Keyboard, don't like mechanicals) and a Headset (looking at the Siberia v2 something). I don't need a monitor as I already have one.
Peripherals should only be around £100
This PC will be used for PC Gaming mainly (the more demanding games), Cinema 4D, After Effects, Premiere Pro and some Photoshop/Illustrator
I will be overclocking, but I like air coolers (Hyper 212 EVO?)
OS is required in this budget. Would like to opt. for Windows 8 (don't hate, I have reasons) with start is back (does not need to be included)
I don't plan on bitcoin.
Game Stuffs-
Settings: High-Ultra (mainly ultra) 60+ fps
1920x1080, not going multi-monitor in the foreseeable future
FPS (Battlefield 4 and a lot of others), Garry's Mod, Garry's Mod, Garry's M- erm... I like that game a lot and pretty much every other genre that isn't Puzzle/Platformers.
Mainly Battlefield 4, GMod, Skyrim, Fallout, XCom, the Arkham games, etc.
Render or Edit things-
Pretty much only video stuff rendered in C4D (not much anymore), After Effects, Premiere Pro or *maybe* Sony Vegas (won't use much though).
Peripherals -
Cheap keyboard
Basically the Deathadder for the mouse
If you find a better Mouse for similar price, then I'd like it to have a pretty high DPI (FPS games)
Partpicker Links that I've made so far:
Bottom of budget: http://uk.pcpartpicker.com/user/Sheepyy_/saved/2ubi
Edit: Have no clue why I have a 200R on it... might've picked the wrong partpickers from a while ago.. I'm using an NZXT Tempest 210 (great airflow) or, if I can stretch my budget, a Fractal Design R4 Windowed
Extra info on Links -
I went for the GTX 670 4GB for a reason
It's stupid cheap in the UK at the moment, but the 7950 Boost/7970 is priced competitively
Battlefield recommended 4GB ._. (I think recommended was @ 1440p, but many Alpha players report Ultra goes just over the 2GB mark)
CUDA
I'm thinking about the Hawaii cards, still not sure how they're gonna be priced in the UK.
Sorry for the giant amount of text, I tried to be in-depth
If you buy any thing from dabs you'll be waiting a while. I ordered something Little over a month ago and nothing.
Now to you build. The CPU fine absolutely nothing wrong with that. Great CPU for gaming performance, even at stock clocks. Your MB is iffy. As rock boards are not great over clocking boards have all right features but nit for over clocking. I would recommend any Asus motherboard that is gaming oriented as this gives you a great digital power delivery for over clocking. Along with all of the Asus exclusive features, such as ai suite and fan expert are really good.
All of the other components are fine for what you want to do. But I agree with you, wait to see what the R9 series brings to the GPU table.
And yeah I so wish I was in the US so cheep for componants. Unlike the UK
Thanks for the reply, and I will consider an ASUS board (the Extreme 3 had more features than similar at that price, so I went for it) any one you would recommend in particular?
Well there are 3 in the main stream value oriented. Form the "- A", the "Pro", or the "Deluxe" board. These are in price order. I personally own the A and its a solid board. If you have a bit more money then opt for the pro or deluxe. ROG board come with some little extra things but on the while not worth it in my opinion.
If you want some details on all of the board then the tek syndicate YouTube channel probably has all of the overviews of them. Or look for the Asus YouTube channel as JJ goes through all of them in great detail.
Also a quick hint. Aria PC don't have the i5 in stock as I was going to by mine from there. And ebuyer is cheaper then them by a few quid. I bought mine from there and came in 3 days with the cheapest shipping option.
I'm no professional, however I feel i should give my opinion on this matter. Like you, I am also from the Uk, North - West to be precise, and soon (preferably in a weeks time[but i doubt ill have the money in time]) I will be buying a PC from a custom built site. I have found a great site called dino pc : www.dinopc.com and 3 of my friends have bought computers from there. And believe me, after many, many hours of research, I have found that this website is the best. I know that this isn't what you were looking to find out, but at least i've told you something. Enjoy your PC!
Thanks for your input, when I was choosing my mobo I heard horror stories about the A series (the ones in my price range, and veered away from them, but am reading up on their reviews now. Thanks.
If there is one thing I can tell you it is that I DO NOT recommend the Razer DeathAdder. I have used it for under a year and the Mouse-5 button has already broken. It also becomes very hot on your hand with prolonged use which might be because it is more of a rubberised mouse. It also becomes very dirty from just normal use.
I would suggest pretty much anything Logitech. I myself am thinking about purchasing the Logitech G600. This video made me interested in the G600.
Thanks for the input, I will reconsider the purchase of the mouse. I'm, personally, not a big fan of any logitech product, as in my experience they have mediocre build quality and are either way too small or too big. I've been looking at SteelSeries products instead, so if anyone has any input on those it would be greatly appreciated.
Also, I've never heard of this overheating issue in the deathadder before, it might be faulty but I'm probably going to get a steelseries mouse (looking at the sensei RAW or Diablo 3)
