8350 oc vs i7 990x oc
So what what would win, an old Intel or a new amd chip. If it looses then what about a 920 or 960 could it win against those.
http://www.anandtech.com/bench/product/697?vs=444 and i assume thats at stock
http://www.cpubenchmark.net/high_end_cpus.html  a better one would be a 9370 vs  i7990x  the reason i say that is that it would be interesting to if 990x could oc up 9370 cause we all know 9370 isnt going to oc very far.
This is the difference between a stock 990X HT vs a 4.8GHz overclocked FX-8350.
Memory Read
8x FX-8350 4800 MHz Asus M5A99FX Pro R2.0 AMD990FX Dual DDR3-2133 10-11-11-28 CR2 27133 MB/s
6x Core i7-990X Extreme HT 3466 MHz Intel DX58SO2 X58 Triple DDR3-1333 9-9-9-24 CR1 21110 MB/s
Memory Write
8x FX-8350 4800 MHz Asus M5A99FX Pro R2.0 AMD990FX Dual DDR3-2133 10-11-11-28 CR2 17940 MB/s
6x Core i7-990X Extreme HT 3466 MHz Intel DX58SO2 X58 Triple DDR3-1333 9-9-9-24 CR1 16673 MB/s
Memory Copy
8x FX-8350 4800 MHz Asus M5A99FX Pro R2.0 AMD990FX Dual DDR3-2133 10-11-11-28 CR2 24136 MB/s
6x Core i7-990X Extreme HT 3466 MHz Intel DX58SO2 X58 Triple DDR3-1333 9-9-9-24 CR1 24509 MB/s
Memory Latency
8x FX-8350 4800 MHz Asus M5A99FX Pro R2.0 AMD990FX Dual DDR3-2133 10-11-11-28 CR2 58.2 ns
6x Core i7-990X Extreme 3466 MHz Intel DX58SO2 X58 Triple DDR3-1333 9-9-9-24 CR1 67.1 ns
CPU Queen
8x FX-8350 4800 MHz Asus M5A99FX Pro R2.0 AMD990FX Dual DDR3-2133 10-11-11-28 CR2 42701
6x Core i7-990X Extreme HT 3466 MHz Intel DX58SO2 X58 Triple DDR3-1333 9-9-9-24 CR1 56836
CPU PhotoWorxx
8x FX-8350 4800 MHz Asus M5A99FX Pro R2.0 AMD990FX Dual DDR3-2133 10-11-11-28 CR2 13293 MPixel/s
6x Core i7-990X Extreme HT 3466 MHz Intel DX58SO2 X58 Triple DDR3-1333 9-9-9-24 CR1 12962 MPixel/s
CPU ZLib
8x FX-8350 4800 MHz Asus M5A99FX Pro R2.0 AMD990FX Dual DDR3-2133 10-11-11-28 CR2 412.9 MB/s
6x Core i7-990X Extreme HT 3466 MHz Intel DX58SO2 X58 Triple DDR3-1333 9-9-9-24 CR1 358.7 MB/s
CPU AES
8x FX-8350 4800 MHz Asus M5A99FX Pro R2.0 AMD990FX Dual DDR3-2133 10-11-11-28 CR2 20566 MB/s
6x Core i7-990X Extreme HT 3466 MHz Intel DX58SO2 X58 Triple DDR3-1333 9-9-9-24 CR1 12247 MB/s
CPU Hash
8x FX-8350 4800 MHz Asus M5A99FX Pro R2.0 AMD990FX Dual DDR3-2133 10-11-11-28 CR2 4882 MB/s
6x Core i7-990X Extreme HT 3466 MHz Intel DX58SO2 X58 Triple DDR3-1333 9-9-9-24 CR1 3137 MB/s
FPU VP8
8x FX-8350 4800 MHz Asus M5A99FX Pro R2.0 AMD990FX Dual DDR3-2133 10-11-11-28 CR2 5695
6x Core i7-990X Extreme HT 3466 MHz Intel DX58SO2 X58 Triple DDR3-1333 9-9-9-24 CR1 5592
FPU Julia
8x FX-8350 4800 MHz Asus M5A99FX Pro R2.0 AMD990FX Dual DDR3-2133 10-11-11-28 CR2 15810
6x Core i7-990X Extreme HT 3466 MHz Intel DX58SO2 X58 Triple DDR3-1333 9-9-9-24 CR1 17993
FPU Mandel
8x FX-8350 4800 MHz Asus M5A99FX Pro R2.0 AMD990FX Dual DDR3-2133 10-11-11-28 CR2 8081
6x Core i7-990X Extreme HT 3466 MHz Intel DX58SO2 X58 Triple DDR3-1333 9-9-9-24 CR1 8672
FPU SinJulia
8x FX-8350 4800 MHz Asus M5A99FX Pro R2.0 AMD990FX Dual DDR3-2133 10-11-11-28 CR2 3298
6x Core i7-990X Extreme HT 3466 MHz Intel DX58SO2 X58 Triple DDR3-1333 9-9-9-24 CR1 7471
yup, i think i have my answer.
Biggest problem for LGA1366 and LGA2011 though is memory speed compatability just like any other Intel CPU made in the last 6-7 years. The memory controller is designed to only run 1333 MHz DDR3 officially but depending on Motherboard manufacturer's QVL you can get anywhere from 16GB of 1866 MHz RAM to work or 8GB of 2200 MHz RAM to work with x58 and x79.
