Right so I decieded to redo the cable management in my computer, and while i was doing that i wanted to see if i could fit my on my Coolermaster seidon 120m the other way around because I thought it would do for better looking management as well, I found out that it wasen't possible when i had already taken off the pump and block.
I then remounted it, exactly as I had done when I first built the computer, and the temps got really high (like 80-90 degrees at load), and my Computer shut down because of it.
I thought that maybe I had done a poor job of applying termal paste, so I took the cooler off again, redid the thermal paste and threw on the cooler again, it seemed fine for a period, not as good as when I had just built the computer, but deffently better than last time. Even in Prime 95 they didn't exeed 72 (still high, but not as high).
It then started to go up again, and when I played BF4 it got to 90 degrees and saftey shutdown.
Idle is at 25-40 degrees (yes I know it's a big difference, but that what it says)
I don't know what to do, I'm at a loss here, I've done everything as it should be done, yet I get these extreme temps
My idle temps before were 18-25 degrees
and under heavy load it was at 60-65 degrees (all in celsius)
I have an Asus Sabertooth 990FX R. 2.0 Mobo with my FX 8350.
Please help, and ask any questions, I'll answer them as good as I can
