I have ripped open the internet attempting to find benchmarks for this processor on this particular game. If any one is able to give me some information for this I would greatly appreciate it! Thanks
seeing as how i have a 8350 and arma 2 but i have 2 hd 6850's i dont think you want my benches but i can post them to you for reference..
tek syndicate did arma 2 in their 8350 v intel tests, but as arma poorly threaded i think they're bullshit
1080p with everything set to highest possible. 3d setting set to 1080p as well
fps min 5
fps max 75
fps avg 32.2 first mission
In multiplayer servers I tested a fx6300 @4ghz vs a i5 3570k @4ghz and the i5 was always about 5-20 fps better depending on the game type and server. Now I know the i5 is not really comparable but arma was only using about 30-50% of the processors
will re test on multiplayer servers with same maxed out settings and let you know what my cpu usage is and my frame rate.
edit 32 player server with 32 players
min 1
max 26
avg 15.36
cpu usage 35%
Thank you for all the replies, I currently have a Core 2 Quad Q9400 and it gets about 22fps on average. The 8350 seems to lack in ArmA series games unfortunately....
I have an 8350 with a 7870 at about 1200MHz I think, may have brought it back to 1150.
In Dayz I get above 60 normally (entering cities or on poor servers changes that a bit of course but never slide shows on me ever, even with hectic moments) with the settings maxed and then stepped down a touch in a couple places with v sync off. At 1920 by 1200 resolution by the way.
I have no real benchmarks and only know the frames because of some servers having he debug monitor.
Arma 3 is very playable honestly too, single and multilayer. The GPU is holding me back with that more than anything. Use the little tweaks out there and the performance is very good though. High settings or better with AA stuff turned down a bit. Wouldn't be getting near 60FPS though (want a nice new card bad haha).
The intel chips perform better generally down to the single core performance. Arma titles are somewhat notorious for not utilising all the proccessing threads available to the modern PC owner. That however does not perclude the AMD chips from top range performance. Balanced against what it does in most games I'll take it.
