8320 vs 3570k
which cpu would be a better combo with a gtx 770 for gaming???
Both are perfectly fine with the GTX 770. Because games are not usually CPU dependent, you won't be able to tell the difference between the two in the majority of games.
I would grab the 8320 with a really good motherboard if you wish to do any kind of editing and or streaming.
I would pick the 3570k or 4670k if you want a small form factor PC, like mATX or mITX.
Are there any specific games that you have in mind? There are a few games that could find either CPU a little preferable. Might be in your interest to design the PC for the best performance in a favourite game.
games like tomb raider, bioshock, assassins creed IV, batman origins
Any of those games will run comfortably on either CPU. You wouldn't notice a difference between Intel versus AMD in those titles.
So go with whichever CPU meets your needs. The 8320 is versatile, while any given i5 will allow you to build a PC inside a pretty small case - because the i5s have a range of different sized motherboards.
which ever is cheaper. the 8350 will proform better in multi processor tasks, and you would want to get that. cpu processors rarely affect games greatly. my i3 3220 isn't even bottlenecking my 7850.
If you are going to get a 8320 you might as well get an 8350.
