8320 and a ASUS M5A97 R2.0
Will these 2 components work well toughter?  I was originally going to go for the 6300 but I think im gonna go with the 8320. Will it work with this board? thanks
Yep, it'll work fine.
It will work but it won't give you much overclocking and multiple GPU features. The 8 core fx chips work best with a 990fx chipset mobo. But if you're on a budget then it's fine.
Unless you want to go crazy with the overclock or run more than one graphics card that mobo is going to do well. I don't mean "it may do", I mean its plenty good enough for any use unless you need the above features, which if you do its simply not going to work in your setup. I will also note that mobo does not support that FX-9370 or FX-9390, even though they may actually plug in and post, it can cause irreversible damage if you do so, so don't even try, your on a hiding to nothing if you do.
So in a nutshell, yes, you won't have problems with that combo, but know the limitations of the unit or your in for trouble in the future.
