My friend wants to know just how good a pc he could get for £800. Would anyone be kind enough to put together an £800 rig on pcpart picker? I have literally nowhere to start with such a high budget.
He has monitors, keyboards and mouse, and a copy of windows.
It is purely for gaming, and he does not want an ssd.
J_T_
August 26, 2013, 11:10pm
#2
http://uk.pcpartpicker.com/p/1wAsW
Amd version
http://uk.pcpartpicker.com/p/1wADj
Amd version has a better gpu and the cpu's are simmilar.
This should be able to run all the games he wants
http://uk.pcpartpicker.com/p/1wAyw
All for £749
http://uk.pcpartpicker.com/user/Killerfrenzy96/saved/2g7C
I think this one is pretty solid!
However, if we cheap out on one or two components, we can fit a decent enough SSD:
http://uk.pcpartpicker.com/p/1wAZW
Better GPU not found on PCpartpicker:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-190-MS
Currently priced less than £200
Thank you. Berserker, your build looks the most solid, thanks.
Here's what I came up with: http://uk.pcpartpicker.com/p/1wB3k
He said he doesn't really have a need for an ssd.
There's virtually no performance difference between an overclocked 7950 and an overclocked 7970GHz
http://youtu.be/7Z6e0UtPZY0?t=2m30s
Save yourself the money.
I'de be fine overclocking it but, he doesn't really want anything overclocked. Thanks anyway.
