$800 Dollar gaming build
I recently got an email about a job offer to fix 7 laptops that I can make upwards a thousand dollars so with my new found fortune I want to build a 800 dollar build here is the build I'm thinking of making
Specs;
AMD FX8350 4.0GHz 179.99 from microcenter
MSI 970-A-G46 39.99 from microcenter
WD Blue 1TB 7,200RPM Sata 6 HDD 67.99 from microcenter
G.Skill Ripjaws X series 16GB DDR3-1866 2X8 Sticks 124.99 from Newegg
Sapphire Radeon HD 7850 2GB GPU 199.99 From NewEgg
Cosair builder series 500w 80 plus bronze PSU  59.99 From NewEgg
Lite-On iHAS124-04 Optical Drive 17.99  From NewEgg
NZXT Tempest 210 case 44.99 From Amazon
The total is around 750 dollars but my budget is 800
Its never dull with you, is it?
http://pcpartpicker.com/p/PKAf
buy a better mobo get a 990fx one you dont need 16gbs of ram anless your doing video work save on 8gbs of ram and put it to a better mobo
970 chipset mobos are old and where not ment for FX chips and most of them require a bios update to use them.
A 990fx mobo will give you more  options for overclocking
And grab a better psu with more power :)
