I'm planning on upgrading my rig and have a budget of $800. This is what I have so far: http://pcpartpicker.com/user/JordanBlake/saved/VmWJ7P
The goal of the rig is to build something to game on, mostly a casual gamer at the moment but I would like to get more into PC gaming. I also intend on using this to do graphic design in programs such as Photoshop and Illustrator. I chose the graphics card because I currently have a EVGA 560 and have been happy and would like to continue my patronage. (Yes, I've looked into a R9 280 so you don't need to bring that up.) I'd like it to be a long lasting machine with room for upgrades if needed.
I just would like confirmation that this would work well for what I need(I don't plan on overclocking). I'm planning on upgrading my peripherals once Christmas rolls around and I have more money to throw at this.
The CM EVO 212 will extend the lifespan of both the mobo and CPU ... highly recommend it. The only problem with the Corsair spec 3 case is that the CPU coolers that fit are expensive or very loud.
You can buy a 3.5" & 5.25" panel that fits where old floppy drives went with USB 3.0 jacks in it for $24
SEDNA - 2 Port USB 3.0 3.5" Floppy Bay Front Panel (2 x type A connector ) with 5.25" mounting kit included
