800$-900$Gaming Build Help
Im coming from a Xbox 360 and a shitty laptop so this is my first build, during boxing day sales i bought the following:
2 TB Western Digital Harddrive
1x8 GB Balistix Crucial Sport DDR3 PC3 12800 240 Pin RAM
Zotac GTX 650 TI DDR5 2GB graphics card
I was thinking of getting:
AMD FX 6300 3.5GHz 6 core CPU
a 650 80+bronze PSU (for like 60-70$)
im not sure for my MoBo i was looking at a Gigabyte GA-990FXA-UD3 for like 150$ but if i get a 100$ or less MB i can get a cheap SSD for my OS
for a case im thinking Cooler Master HAF 912
So im hoping for some advise and critics etc, and some suggestions, thanks
Wait so have you bought it already or are you thinking of buying it?
So you bought:
WD 2TB HDD
Crucial Ballistix Sport DDR3-1600 (1x8GB)
Zotac GTX 650ti 2GB
Well TBH, you created a bottleneck for yourself with that 650ti.  It's weak for the budget given.  It's an extremely budget card.  The RAM will also be in single channel, until you get an identical stick.  Dual channel is often up to 50% faster in daily usage than single channel.
http://pcpartpicker.com/p/2wlsu
SLI ready, 8 core CPU, and overclockable if you buy a CPU cooler.  Nice high quality case, SSd + 2TB.
Don't know why you got the 650ti.  The rest is workable, though.
Hey there,like others I'm surprised you went out and bought such a low end graphics solution, its really going to be the bottleneck of your rig. However never fear you'll still get decent gaming even on that hardware. Others are saying duel channel is much faster, even 50%, this isn't normally the case. Duel channel memory will run faster, however in most applications the speed difference will not be noticeable, and you can always add a second stick later, I do however find the choice strange given your looking at a ATX mobo and will most likly have 4 ram slots, so you could upgrade even if you bought a duel channel kit.
All that aside regarding what you want to buy now I'd be looking at a Asus M5A99FX PRO R2.0 motherboard, they are very good boards that will allow you to run any current FX chip including the FX9590 so its very upgradable. I'd also look at getting a cheaper air cooler, AMD's chips FX chip actually overclock well but there coolers are not only loud but also very low performance, some thing like a Hyper212evo ($35) or NZXT T40 ($30) is a good starting point although a Noctua NH-U12P SE2 will be much quieter (near silent), has duel fans so should cool 10-20% better and has better mounting hardware for about $60. I'd splash out on the Noctua cooler because even after you upgrade your CPU or even on your next build it'll still work well, and silence truly is golden when it comes to PC fan noise. Regarding a CPU, the FX-6300 is a solid choice, it performs about as well as last generations I5 processors and isn't too expensive, its also far more than you need for gaming on that graphics card. Regarding your PSU, I'd go to a Antec 620watt High Current Gamer Modular its only about $60 at the moment and its a quality unit, although really anything over 600watts and bronze or higher certified will work if you stick to the name brand supplies, but personally I'd avoid the Corsair CX series, they have high current ratings and modular design at an attractive price point but actually lack the build quality or reliability that we've come to expect from Corsair, from reviews the lower end GS units have the fallen to the same fate, although Corsairs other power supplies still all seem to be decent. Finally regarding your case its mainly a personal preference thing regarding the looks, but personally I think the Fractual Design Cases are some of the better value for money you can get, I have a Define Black Pearl (non-windowed) and its well made, well thought out, ventilated well and much quieter than most cases due to full 140mm fans, interior sound deadening and covers for unused fan slots. However the Corsair 200r is also great value if a war on noise isn't your thing, offering a very small footprint, but a full 8 expansion slots, large CPU cooler and long graphics card support, good ventilation (5x140mm fans 3x120mm) and 4xHDD's + 4xSSDs. Other honorable mentions go to the CoolerMaster CM690 III (3x200mm fans, clean styling and good design and build quality) and HAF XB (massive interior space and ventilation due to horizontal cube case design).
I was on board till you said a 6300 will perform the same as ivy bridge i5..... then I jumped off ship....
Hell I'll put my sandy bridge i5 up to it... Intel vs AMD per core is 1.6:1 and my sandy i5 oc to 4.5 everyday but maxes stable @ 4.8.. 1.3v....
Keep in mind most apps are single threaded... and beyond that it takes a pildriver to compete with i5... not even a fanboy here I like price/performance but a 6300 isn't comparable at all to an ivy i5.... or a sandy i5 for that matter.... if you want price/performance go and...  but performance alone is Intel's throne by a big margin
I would say a 6300 is right below or around the low end i5s.
Pretty good, considering they're usually $110 bucks.
