Just updated to windows 8.1 and the ui i massive how do i fix this?
I have already checked the resolution options, both in windows and the nVidia control panel
Are you talking in like metro tiles or on the desktop?
desktop, mouse cursor, task bar, even the url bar and tabs in my browser
Also webpages are zoomed in by default
On your browser is the view set to 100% or more?
i found the answer
go to Control Panel\Appearance and Personalisation\Display and change the setting to smaller (100%) for some reason 8.1 changed it to larger by default so a lot of things were zoomed in 150%
