i have a xfx 7870 and i updated to 8.1 is there a bug with the drivers because i have updated and uninstalled and reinstalled the drivers and it still pops up saying the amd drivers are nor recognized or not there. Also it said i have a code (43) is there any way to fix or just want on new drivers.
You using the 13.9 version?, think that's the one that has 8.1 compatibility.
http://support.amd.com/en-us/download and find your driver
Yes i have and i have reinstalled and uninstalled a few times still not working
have you tried the 13,11 beta driver?
http://support.amd.com/en-us/kb-articles/Pages/latest-catalyst-windows-beta.aspx
Yes, same problem I am going to reinstall win8 until I find the problem
odd question i suppose....have you tried just using the windows 8 driver? It may still work fine on 8.1 im not sure if they did any major changes to that side of windows 8/8.1
First i think you should looking for some malaware on your pc including the boot . Second it is possible your download got corrupted. So a fresh install might be in order.
Will try how do u install windows8 over 8.1 i tried to and t said that i need different files that are not on this media disc
I meant a fresh download and install of 8.1 .
how with the 8.1 RT
