7970 only Running PCI-E 4x (solved)
Hi everybody! after months of beeing a youtube creep that just subbed there and stuff i finally slapped me a account on here since i was unable to google my issue :)
I noticed since days that my Gigabyte 7970 ( GV-R797OC-3GD ) ony runs on PCI-E 4x mode.
Not so sure if it was since i build the pc but GPU-Z and in linux i get a 4x PCI-E readout.
LnkSta: Speed 2.5GT/s, Width x4, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
So i am confused what might be the issue. I don't want to go out and blindly RMA or buy a new PSU and motherboard.
Also the GFX uses the default small power plug from the psu and the dual molex adapter since that dam PSU is outdated...
Specs:
GFX: Gigabyte 7970 ( GV-R797OC-3GD )
Mainboard: GA-990XA-UD3  (rev 1.x) (edit, posted wrong name >.<)
AMD FX-8320
Patriot 8GB 1600mhz
Creative X-Fi Fatal1ty (old pci card)
PSU: be-quiet BQT-E6 700W
Just curious, why are you using a molex adapter if the spec sheet for that PSU states you have 2 6+2 pin PCI-e power connectors?
i do but they are backwards. i would have to soder them off and the other way round on.
Pictures? Explain to me how the connectors are backwards, it doesn't make any sense unless you have a PSU that was improperly built.
Sorry about the quality but that was the only charged cam around the house and thats pretty much how the plug looks next to the molex adapter i use. i cannot put it on the other side because its too short.
I really tried putting that upside down and so on..
Also i changed the slot of the GFX and it works in the middle PCI-E slot with PCI-E 8x.
....WEIRD
Pull out the pcie card the gpu will run at x16 (i asume you have the pci card in the x8 slot?)
From gigabite --> ((Note 4) The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When the PCIEX8 slot is populated, the PCIEX16 slot will operate at up to x8 mode.
i tried with the soundcard removed. it still was at 4x.
besides it was an PCI card not PCI-E
So you have this card in the first full size PCI-e lane on the board? and its reading as 4x..... hmm
I know its a long shot, but try updating the Mobo BIOS to a newer version.
anyone correct me if I am wrong,
But the red one is for PCIe, and the black one is for CPU.
done that too. F14b and F13, no differences.
I think i should just buy a new board.
Have you tried with the GPU in it's two different BIOS states?
yeah.... that dip switch was it seems on backup bios.
I feel kinda stupid now that i did not try that. :) thank you :O
So its working now?
yup 16x PCI-E it reports back now.. :)
