I was just wondering if it's possible to pair up a ASUS HD 7950, with my XFX 7950 in crossfire? Or do they have to be exactly the same model, from exactly the same company? Also, if i did pair up an ASUS 7950 with an XFX 7950 would I run into any problems? For example stability issues.
Yeah, this is maybe something that speaks for itself, but do allign the clocks if they are diffrent, or you're wasting power :) (they will allign to the slowest speed.)
I don't know if you would run into any glitches because of different clock speeds, but the faster card would downclock itself to match the performance of the weaker one.
true, but some 7950 can be unlocked, always been a thing with the x9xx. I know the Sapphire and HIS with the 7950, don't know if it's the reference model or the non-reference though.
Actually, we got screwed with the 79xx series. All of the extra shaders were lasered off, and they cant be unlocked. You could with the 6 series, but not the 7 :(
DAMN! good thing i didn't pick one up, i've been contemplating to get the 2 x 7950 when 9-series gets launched because of the price drop. guess i'll wait to see if 9 series will be a good enough. 6950 to 7950 wasn't that great of an improvement, especailly after the 6950 got the bios flash. Have MSI 6950 TFIII flashed to the Lightning spec. wasn't worth upgrading, but if that's the case, i won't upgrade till 9-series or maybe GTX 760ti.
