Hello All,
I just got a new xfx Radeon 7870 2GB, and the WEI is only at 6.0 for both graphics and gaming graphics. Surely this is incorrect.
Help please?
Hello All,
Help please?
WEI is shit, dont listen to it, but it does rate my gtx 480 at 7.9
Is anyone else experiencing driver issues with the 7800 series?
I have a 7870 and get 7.9 on windows 7.
7.9 is the highest you can get on windows 7 because you know a scale from 0 to 7.9 makes a bunch of sence.
If you are running vista and are actualy getting 5.9 and decieded to round up then dont worry as 5.9 is the max for vista.
Not getting as high frames on far cry 3 as I had hoped.A bit stuttery at times on the higher settings.
