will the 7950 still perform to its fullest with these components?
Case- Zalman z11 MB- MSi 970A-G46 (I don't think this allows me to utilize my USB ports on my Case) CPU- AMD FX6300 RAM- 16gb corsair vengence ( 1866mhz, Got it half price so) CPU Heatsink - Hyper 212 evo PSU- Corsair CX600 SDD- HyperX 3k 120g Still need a HDD and GPU also probably some extra cables as such as well as some extra fans
Also is there anything you could recommend other than GPU? I think I want to change my motherboard purely so I can actually use the usb headers on my case. any ideas which would fit in well with this build?
From what I can tell you prefer AMD, and favorite MSI. I'd like to you consider the following items I threw together for you: (Everything below is compatible)
Case: Zalman z11 Motherboard: MSI 970A-G46 CPU: AMD FX-8320 CPU Cooler: Cooler master hyper 212 evo RAM:Corsair Vengeance SSD: SanDisk 64GB (for windows and boot apps) HDD: Western Digital Blue 1TB Graphics card: MSI 7950 BE Power Supply: CX 750
The CPU gives you a bigger bang for the buck, anyone will contest AMD CPU's but the fact is you need one under the criteria of 1.) it's fast and 2.) it works.
A 600W power supply will work but a 750 will allow you to crossfire or upgrade that graphics card a year down the line.
When it comes to SSDs the bigger the faster, so going for a 120 isn't worth it, windows 7 alone only takes about 30gb IF that, after updates. So 64gb saves you some cash. Go for the 120 if you play games with a lot of loading screens, going from place to place like Skryim, or borderlands 2.
You'll see there's the Western Digital Blue, and Black. There is no difference to the casual user. Save some money.
the thing is everything I've already mentioned I've bought. I was mid build when i lost my job. the reason for the 120 is yes, I play Alot of games like skyrim and borderlands and what not. also I'l probably need a larger hdd as theres going to be ALOT things going onto it. about 20k songs about 300 movies and alot of large games
Also I don't necessarily prefer MSi It's just what I got reccomended
so you definitely recommend the 7950? the reason I ask is logan said in one of his vids that he took out a 7970(which I imagine is better than the 7970) and put his 7870 back in because it ran the same but cooler. maybe a miniature fps drop
