Is the
VTX3D AMD Radeon HD 7870 Graphics Card - Black
a tahiti LE edition or isn't it? If it isn't can you say what one is?
Is the
you want the sapphire 7870 XT with boost
Powercolour 7870 myst edition
or royal 7870 joker card
They are all Tahiti LE the vtx3d is not, i dont think they have one yet
Ok thank you :)
so is this a xt/tahiti LE card?
Just look at the Stream processor count and you'll know what kind of card it is.
1024 Stream Processors = Pitcairn Pro (HD7850)
1280 Stream Processors = Pitcairn XT (HD7870)
1536 Stream Processors= Tahiti LE (HD7870 XT)
1792 Stream Processors = Tahiti Pro (HD7950)
2048 Stream Processors = Tahiti XT (HD7970)
ok, now i'll be fine with searching for the tahiti le cards
So is this card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202024
better than this card?
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161404
It has a newer chipset so i think so
here is the review i found there is also a video review buy tastypc on youtube
http://www.kitguru.net/components/graphic-cards/zardon/sapphire-hd7870-w-boost-tahiti-le-review/
