Just curious, once HSA is supported and the GPU acts as compute units, will memory speed affect the compute performance or will memory speed still only really be important for higher framerates if you're using the integrated graphics instead of a dedicated GPU?
It should affect both compute and gaming performance, I would assume.
I suppose I should invest the extra $10 in 2400MHz ram anyways. Even if it turns out the memory bandwidth isn't a big issue then I can run it at 1600 with a CAS of 6 or something like that
Fast memory in an APU set up will only really effect the GPU portion.
As for the CPU portion, it will do just like it does for any other CPU, which, isnt much.
Right, and HSA allows for the GPU to access the ram for GPU compute tasks (gaming or not). So in theory, faster ram should speed up any processes using the GPU portion of the APU, not just gaming performance.
