Ok so I am in the process of building my first pc, and I want to make sure that it can out preform the xbone and ps4. I am on a budget so a 7850 appeals to me. Can I run new games like bf4 on better than console settings? Is it worth it to spend the extra money on the 7870? I am going to be using the athlon 760k cpu with the gpu if that offers any help.
7850 is competitive with the PS4, which is the most powerful of all the consoles. So it doesn't beat it entirely across all given games. However, in Battlefield 4, where Mantle has been implemented, you will certainly play that game on ultra settings at 1080p.
The PS4 runs BF4 at 900p, so you certainly beat the PS4 in some sense. The PS4 might have a higher frame rate, but not relative to your preferred (likely 1080p) resolution. It sacrifices some graphics fidelity to maintain that frame rate. So it is arguable that the PS4 will be faster, but th 7850 will make BF4 look better.
I can't promise you that it will run all games on ultra. Some games may require you to turn the settings down to high or very high. It is an impressive card. I would advocate spending an additional part of your budget on a 7870 or R9 270. These cards are higher performing, and they are much more capable. They certainly beat consoles in all given games.
The 7850/7870/270 will work great wit the 760k.
At 1080p you should have much of an issue running may games maxed. A few you may have to turn off the fancy filters and AA but it will still look very good.
I have a 750k and 7850 Oc'd to 1100 MHz (they are really good overclockers). In battlefield 4 mp at 1050x1680 I can easily run at high settings, staying over 40fps for 95% of the time. I usually run it at medium so I can stay above 60fps constantly. battlefield 4 is the only game i haven't maxed out.
I love my 7850-you cant go wrong, probably the best price/performance card out there.
Ok thanks for the help everyone I think I will get a r9-270 or 7870 depending on what is cheaper at the time. Either way it will be a welcome upgrade on my laptops a6-4400m!
You are putting this in a desktop right? You know you can't add a GPU to your laptop... right? Please say right.
DerKrieger I hate to derail this thread, but can you check you PM?
Yes yes I know!:D I was worried someone would think that:P
