I know this must be a stupid question but i want to know if I can run both of these cards in sli... Just a yes or no answer is enough.
I doubt it. The differences extend much farther beyond core clock and memory clock speeds.
Sure you could, they are essentially the same card, but it's gonna downclock the 780Ti to the same as the normal 780, so there's really no point in spending extra for the 780Ti.
You're better off getting another normal 780 my friend. (If that's what you're planning)
Edit: I did some digging and it looks like you cannot SLI a normal card with it's Ti counterpart. So don't bother getting a 780Ti, unless you intend on outright swapping it with your 780.
NOTE: core clocks and memory clock do not matter while crossfiring with amd though,... only the core does. you can drossfire a 7950 with a r9 280X if you wanted to because they're both tahiti.
I can't say anything for Nvidia though.
As far as I know AMD only supports mixed card setups.
That's what I thought I said :P. Anyway...
I don't think they'd SLI as they have different amounts of stream processors and texture units.
that's what i was getting to. on the amd side a 7950 and a 280X (7970) will corssfire because it's the same family core. even though one has 256 more stream processors.
I can't speak for the Nvidia side though. [I'd hope it works the same way]
Short answer is NO. Nvidia has never allowed mixing of GPU's, unless they are 100% identical.
