770 GTX SLI-Are these numbers decent?
Just got the second card today and got these marks in unigine heaven:
FPS: 80
Score: 2024
min FPS: 23
max FPS: 159
extreme preset
I have never done this before, I mean SLI, so I would just like to know if anyone here with experience can tell if these numbers are to be expected with this setup  because it would be a shame if I'm not getting the most out these cards.
Thanks
Sounds about right; my single 680 4GB @ 1300 something mHz  GPU core got a little under 1000, iirc, on the highest possible settings I could select at 1080p.
What resolution did you run it at? I get about 1400 with 2 660s so 2000+ with 2 770s sounds about right.
