750w PSU enough?
I'm concerned that the PSU won't handle this build. The minimum recommended for ONE of those video cards is 500w. Should i be looking for something in the ~1000w+ range?
Also, would i be able to run the HDDs, DVD, and 11 case fans off a single SATA string (4 SATA connectors per cable?), or would that bee too much amperage for a single cable?
more than ample, a 7870 pulls in the neighborhood of 200 watts at load
Another question. If a PSU is overdrawn, will the computer SUDDENLY shut off, or will it "Shut Down" in the conventional sense (start, shut down)?
I ask because i was running some tests, and in the process of installing something, it suddenly asked to force close the installer because it wanted to shut down. Could this be PSU related? I don't know what would have induced such behavior...
Usually it suddenly shuts off in an attempt to protect itself.
750w is a lot more than what you need for two 7870s.  Your power supply is of decent quality, so I don't think it's the PSU.
This ASUS PSU Wattage Finder Thingy is suggesting at least ~1000w for this build.
Do the 11 case fans make that much of a difference?
I appreciate the responses thus far. It's not that i don't trust the suggestions, I'm just trying to err on the side of extreme caution, bordering on lunacy. I've been working on this rig slowly over a year, and want to check and re-check that everything is hunky dory.
11 fans running full speed would be max 50W draw assuming most fans draw 3.5-5W.  As long as you are getting a good quality 750W PSU, you will have no problems with this build.
It's a Corsair HX750 (OEM Channel Well). Have heard mixed things about Corsair (depending on series). Though i've heard mixed things about many PSUs (SeaSonic included)...
That PSU would be fine.  I have the HX650, although I am not doing SLI
