New motherboard here,
https://uk.pcpartpicker.com/part/gigabyte-motherboard-ga990fxaud3
not added it yet
not added it yet
Yes, that's an acceptable choice if you desire to have the colour scheme.
I should work fine then, I hate motherboard shopping. don't understand. I can beryl find something with the right socket. Also if I do add more fans either the same that is in or cosair air series af 120/140s how will I get them all to work off the one 3 fan controller built in. The room I want to put this in has a large wall mounted tv so I love to connect it up to that to have a nice htpc. It's not a priority btw just wondered.
You can attach multiple fans to each header. Use a 3pin splitter. I have a 6way braided cable that I bought here:
http://www.kustompcs.co.uk/cgi-bin/ss000003.pl?page=search&PR=-1&TB=A&SS=fan+splitter&ACTION=Go%21
They have a nice selection.
My final build, if your interested. Swapped out the ram, and mobo:
http://uk.pcpartpicker.com/user/Epic_BIG_C/saved/3LhG
Massively over budget but I can't help myself. I see it, I want it
I was wondering about dual-booting osx which would require a intel processor. Its more but the motherboard is less so it averages out:
-http://www.amazon.co.uk/Gigabyte-Motherboard-4thGeneration-IntelCore-Processors/dp/B00CUYOWMG/ref=pd_bxgy_computers_text_y/276-5424602-6691746
-http://www.amazon.co.uk/Intel-3-10GHz-Extended-Technology-Execute/dp/B00EF1G8XI/ref=sr_1_2?s=computers&ie=UTF8&qid=1396114255&sr=1-2&keywords=i5+4430
