$750 LAN Build
Hey guys, im interested in building a LAN Pc for bringing to LAN parties and i dont want to spend more than $750. We play mostly older games, so the rig does not have to be a absolute powerhouse, but it should be able to perform decent on current games. Im fine with either an Intel build or AMD build, but on this budget i know i will probably end up with AMD (nothing is wrong with AMD processors). 4 gigs of ram should do fine, and i would love for this to be a mini ITX build. Something that can be easily brought from house to house. Any suggestions for parts is appreciated. Thanks
http://pcpartpicker.com/p/MDgG mini atx amd (you cant get good m-itx for amd)
CPU: AMD Phenom II X4 965 Black 3.4GHz Quad-Core Processor ($84.99 @ Amazon)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.98 @ Outlet PC)
Motherboard: ASRock 960GM/U3S3 FX Micro ATX AM3+ Motherboard ($60.97 @ Newegg)
Memory: Mushkin Blackline 8GB (2 x 4GB) DDR3-1600 Memory ($57.99 @ NCIX US)
Storage: Western Digital Caviar Blue 500GB 3.5" 7200RPM Internal Hard Drive ($59.99 @ Newegg)
Video Card: Gigabyte Radeon HD 7870 2GB Video Card ($229.99 @ Microcenter)
Case: Fractal Design Core 1000 USB 3.0 ATX Mid Tower Case ($38.53 @ NCIX US)
Power Supply: Corsair CXM 600W 80 PLUS Bronze Certified ATX12V Power Supply ($59.99 @ Microcenter)
Optical Drive: Asus DVDE818A7T/BLK/B/GEN CD Reader, DVD Writer ($18.84 @ NCIX US)
Total: $641.27
Well, I went underbudget, but it'll play most games and is nice, cheap and small for a LAN rig.
http://pcpartpicker.com/p/MDnK
$750 is a bit low for mini ITX, this was the best I could do.
http://pcpartpicker.com/user/armypig/saved/1oin
i could stretch the budget to $850 if absolutly necessary. But thanks for the help so far!
intel m-itx http://pcpartpicker.com/p/MDwy
CPU: Intel Core i5-3570 3.4GHz Quad-Core Processor ($207.98 @ SuperBiiz)
Motherboard: ASRock H77M-ITX Mini ITX LGA1155 Motherboard ($89.99 @ Microcenter)
Memory: G.Skill ECO Series 4GB (2 x 2GB) DDR3-1600 Memory ($43.99 @ Newegg)
Video Card: EVGA GeForce GTX 660 2GB Video Card ($203.98 @ Newegg)
Case: BitFenix Prodigy (Black) Mini ITX Tower Case ($79.99 @ NCIX US)
Power Supply: Corsair CXM 430W 80 PLUS Bronze Certified ATX12V Power Supply ($52.98 @ Newegg)
Total: $757.74
I would advise against buying a lower end GPU to get a higher end CPU on a gaming rig.
I eliminated the pointless aftermarket CPU cooler, and adden anouther case fan to my build.
http://pcpartpicker.com/user/armypig/saved/1oiI
the gtx 660 is still a good gpu and was picked for its blower that blows air out of the case va its front io shield and not in to the case like most fan vershons
Thats a good thing for a itx sized case ^_^ but he has sead he can go up to $850 so you can get a 660ti in there for that
