Here is my list for a $700 Gaming PC Build:
http://pcpartpicker.com/user/Shredder2600/saved/sKFmP6
I already have a hard drive. I am purchasing the OS from the MS key store. Please don't create new lists, just tell me what I change.
Looks great, you could save some money by using an R9 280 instead.
Psu is overkill, since you have no cf or sli support on that mb. So something the is 550-500 watt bronze or even something like a 450 gold would do nicely.
yes, but at the moment its an amazing deal for the money, so i can use those extra watts later with an extra gpu or something.
If you will ever want to use two gpu's, you will need a crossfire / sli capable motherboard. The ASRock z97 extreme3 fits your budget just fine.
that pushes me to $760... look at the base total, not the rebates, because thats how much i have to pay upfront.
Ah but here is the deal. Since your will have to build another system anyway, your gonna want a new psu verses a used one. Just to be on the safe side. i have a policy of new psu and new hdds. Saves alot of headaches. :)~
