$700-750 Build Questions
I know a guy who who is interested in having me a build a PC for him.  He would like to spend under $750 on it, including Windows 8.  It will be used for gaming and possibly video recording.  So if you guys could give some suggestions on a list of parts then that would be great.
Thanks a lot guys.
What games specifically?
Is he recording/editing professionally?
How much storage does he need and is an SSD compulsory?
Not sure exactly what games but he might be playing some of the new FPS games that have come out.  The recording and editing is not professional,  he just  might want to start a youtube channel for gameplay and such.  I don't think an SSD is necessary, so I think a 1tb HDD will be fine.
What phiros said....... But I'd be happy to do a parts list
Does he use more Cuda or open gl?
I'm not sure.  He's not super "Techy" and like I said,  It's going to be mostly for gaming and simple tasks like web browsing.
What games will be be playing more fun or more or like minecraft
Fps** mmo***
lie to him tell him that's too cheap for a decent gaming build. build it at 500, keep the rest. profit. then marry his sister for good measure.
Here is my parts list
http://pcpartpicker.com/p/2qP3F
Anarehist u are a dick I'm 13 and more mature than you
Could've gone with an 8320 but with his given description I can tell he not going to be comfortable overclocking
http://pcpartpicker.com/p/2qPhd is $800
You can skimp on the PSU quality and get a cheaper 80+ bronze one. Can Also skimp on the HDD for a caviar blue instead. The Define R4 is a nice case but can obviously go cheaper. The Arc Midi R2 is $20 cheaper.
The fractal design core 1000 is a great case
And the gpu sucks nuts ^o^
here is what i would recommend: http://pcpartpicker.com/parts/partlist/
If i were you, i would spend the most money, to get a decen't GPU. I choce the GTX 760, because it is really well performing, and it has nVidia shadow play feature, wich your friend could use to record the gameplay, and it would not affect his framerates.
That's why i went with the FX 6300. it is a very low cost CPU, for still giving you great performance, and 6 cores, wich would speed up the editing process.
The mobo is a solid choice, wich could handle even overclocking.
8 gigs of 1600 MHz RAM will be totally fine, and will not run out at any gaming scenario
500W PSU will be enough for this system, wich shouldn't take any more than 400w MAX
The Corsair 400R is a great gaming case, with everything your friend would need, great airflow, great cable management, and a solid build quality, and it doesn't look bad at all :)
i hope i helped you, and great time building the PC! :)
wrong link there, this is the correct one http://pcpartpicker.com/p/2qUjE, and i forgot, the CPU cooler is a great choice, it's cheap, but performs like a low end watercooler, and it will run pretty quiet
http://pcpartpicker.com/p/2qUUf
the m5a97 r2.0 is bad. the m5a97 evo r2.0 is much much better.
overall a great build and found a cheap 7950 from sapphire. fx 8320 is really really cheap. and the nzxt t40 is great and it fits witht the ram cuz it's lp ram.  you can't beat it
but the problem there, is that you can't fit windows in your build mister, and recording with that rig, would affect the fps quite a bit, so i wouldn't reccommend the 7950 for a youtuber
and the 760 performs overall like a 7950, plus it has cuda, wich would boost up the editing, and you can't beat that shadowplay :)
show me benchmarks.
amd has his own record software. it's available with raptr app. and why buying windows? pirate bay and most people have a copy of windows 7/8.  7950 is also highly ocable.
well. if you start with editing 1tb isn't enough. and i don't know much but most youtubers have 16-64gig.
i think you should go with the fx 8320 and a good mobo with a cpu cooler and the ram in my build. case is your choice ofcourse. but the 7950 is great for gaming and mantle is a big thing. and gsync isn't that great atm. because you need a new screen. and amd has some software equal to shadowplay. 7950 is really ocable wich is nice. if you really want youtube you should spent more money. more hdd, ssd, ram, and cuda is nice but expensive.
don't know if i can this question but why you want to start youtube? youtube is bleeding cuz you can't make money with videogames anymore (in my country). and 4k rendering is a pain in the ass.
