I am building a budget gaming PC and I only have about $70-$80 dollars to spend on a Graphics Card. I was going to get the GTX-630 (or the GT630 I don't remember) but in one of the episodes of The Tek I believe Logan said it was terrible, so I was wondering if anyone knew of a better graphics card for about that price.
For that, you will be able to get 7750 or perhaps the 7770 if you can find a deal. I believe in Amazon you get the sapphire 7770 for $80. Or you can wait until Black Friday and see if you can get a deal on a 7790 or if you are lucky a 7850 for cheap.
Thank you i think i will get the gtx 660 on black friday but do you know any decent memory kits, i need 2 sticks of 4 and i dont want anything fancy i just want something that will work, do you have any ideas?
Short answer is no don't buy a gtx 280 its a 236 watt part versus the other to are 49 watt and 110 watt and has less cuda cores then the gt 640 and 650ti. Not to mention the floating point performance is half of what the 650 can do.
