6950 Upgrade route
My question is this, im thinking about getting a used 6950 to put in my system to run in crossfire along with my current 6950.
Would this be a good idea, or would I see a better return on selling my 6950 and getting a new card and if so whats best to go for?
I game and currently have the card hooked up in eyefinty to 3 24" 1920x1080 panels
Thanks in advance
6950s run for around 100$ depending on the model, a 7950 would cost new around 200, so both option would cost around 100$.
A 7950 is around 50% better than a 6950 and overclocks nice, has warrenty, would come with 3 games and be new, two 6950s would perform a little bit better depending on scaling and oc potential, but youd have the drawbacks of noise, power consumption, heat and possible issues. Id get the 7950 or something evene better depending on the budged.
If you want to run everything on high or maxed with 3 monitors you should get 2 7950s or wait for the r9 gpus.
I would hold on and get a R9 280x for 299 when they release soon as I have heard they are a really good 7970ghz edition GPU's
