I have a 6950 Direct CUii 1gb card and I want to attempt to unlock the shaders by flashing with a 6970 bios.
I heard that it works 50% of the time but if I brick my card, I have heard that I may be able to throw another 6950 in and recover from the second card's bios? How exactly would I go around to doing that?
Note that this non-reference card does NOT have a dual bios switch.
Would it be easier to just sell it off/trade for another non-reference 6950 with a dual bios and attempt to unlock the shaders?
On another note, if I flash two 6950s, and both are the same make and model of card... Can I still use them in crossfire?
My understanding is that only the reference cards and a very few select others could be flashed. I had the Sapphire Toxic version with the switch and it didn't take the flash, but I had another sapphire card with a switch and it took and I crossfired them perfectly.
It doesn't work on the 1GB models. Only on 2GB because the 1GB model is a cut version.
It MIGHT work but i highly doubt it because the 6970 only came 2GB and 3GB version.
If you do flash it, the 6900's have dual bios with a switch, idk if the DirectCU uses bios switches, but that's very important. It doesn't matter if it is reference or non-reference. I've got 2 MSI 6950's bought a year apart and they both flashed perfectly with no problem...though MSI actually released a modded bios of their own to unlock the cards.
You can crossfire any version of the 6900's. You can have a 6970/6950 or a 6990/6950 combo if you like. As long as it's within the same branch of that series.
You can unbrick a 6950 by simply flashing with ATIFlash in DOS mode. They don't even have to be in crossfire because it just reads the lane. It's very simple, You'll want to make sure that you format their memory and run ram clear on reboot so that you don't re-brick
so on Atiflash it would look like: " atiflash -p -f "card slot number from 0-3" "bios file" "
I would strongly suggest to do that instead of running the windows version because it can crash the OS which means corruption on the video card. Have had it and bricked my video card so i had to swap cards and flash in DOS.
Also, most people that did flash the bios used the Sapphire reference 6970 bios...it's the official card manufacturer that AMD used as the 6970.
Thanks for the help, I'm going to trade up to a 2gb version with a dual bios switch and may add another card later.
At least now I know what to do in the worst case, I should be good to go. I may just wait to see the results from mantle and then upgrade to a 7xxx or a r7, r9
I did this for 2 years ago on my reference card with a bios-switch. So I flashed ha 6970 bios on the first bios slot, but after some days I learned that the voltages or something were higher on the memory so the card would die quicker. Then I flashed a modified 6950 bios and it have worked for 2 years now so...
