I just noticed that my 6900XT is only using 8 lanes on the x16 slot. Not sure how long its been like this. I know it shouldn’t have a noticeable affect on performance, I’m just wondering why it is doing that. It is not my intention to limit it to 8 lanes.
I have Gigabyte X570 Aorus Ultra, 5900X, SN850 PCIE Gen 4.0 NVME m.2, 2x SATA SSDs, 4x 8GB DDR4.
6900XT is in the first slot of the board, highest/closest to the CPU.
Gen 4.0 NVME is in the first slot of the board, highest/closest to the CPU.
I don’t think that just a single 4.0 NVME drive limits your x16 slot on X570 platform.
I think both the top two slots can be adjusted for bifurcation, see if you have this enabled as described above and see if the BIOS is only allocating 8 PCIe lanes to the top slot.
If top slot is occupied and second is not, all 16 lanes are active on top slot.
If second slot is occupied, x8 to top, x8 to second
Third is always x4
The first m.2 is always x4
Second m.2 share two lanes with third m.2 for x4/x0 or x2/x2
Make sure your card is in the proper slot then report back. The good news is that you are losing like 1 FPS, tops, in a x8 4.0 card, so no real loss other than satisfying your OCD.
