im very confused with this... moreover can i use a 650ti on an gigabyte ga h77m d3h motherboard
[img]http://i.imgur.com/yGPM9Ev.png[/img]
[img]http://i.imgur.com/4kl3ZIX.png[/img]
my mobo supports only crossfire... but then is this card compatible with it( ga -h77m- d3h)
Thay will both fit on any mobo that has a pci e x 16 slot so yes it will work
650ti has nvidia shield support and cuda+1 imo
save up for the 7850 instead.. may be a bit more expensive but it's quite a bit better
Why not go with the 650 ti Boost. It can compete with the 7850 for a lower price
my bad sorry those benchmarks were for the 650
this is the 650ti vs 7770:
http://www.anandtech.com/bench/Product/536?vs=680
I opted for the 650Ti and its performance is pretty good, not as good as my 7950 of course but if I were to get a card now I'd go for a 650Ti Boost.
