i have a choice between a :
1gb EVGA geforce gtx 650 ti (140$)
or
2 gb ASUS radeon hd 7770 (130$)
im on a strict budget of 500$ for my whole cpu
which one is better?
or
The 650ti will beat the 7770 9 times out of 10.
to combat the 650ti at that price point AMD just released the 7790, but it's still new and over your budget @ $150
go the 650ti
i'd suggest modifying your build to fit a 7850
I'd suggest waiting for the 7790. They're suppose to hit the market in masses during the first week of April at $150, though a manufacturer might have a promo/sale.
There is one available now though from Sapphire
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202028
@ $500 i just don't think he can. even if it's worth it.
7770 is legit it'll run some games for you. I've never used a 650 ti. Seriosly though the best bang for your buck video card is a 7870 when you can get them on sale.
do you think that the 7850's price would drop by july?
sadly in canada that would probably never happen :P
looking @ 7850, i'm seeing lowest around $175, most around $200 and a few $240'ers. Will there be a drop in july? I don't think so. a price drop would be cause by a release of amds next gen, which isn't until '13 Q3/Q4 (rumors) unless it's a 4th of july sale! :P
So no, i don't think there will be any price drops, unless it's a promotion/sale
would you reccomend a gtx 570 , its on sale for 150 right now :D
it's a generation old. but for $150 i would beat you to it if i had the money.
yes it's worth it
would you take it over a 650 ti or a 7850 or a 7790?
YES. that sale, is too irresistable
