$650 Pc Build
What do you all think of this? http://pcpartpicker.com/p/y14n
i am open to changes i also wouldnt mind going over some.
Edit: There is no storage bc i already have a HDD and SSD
Thanks!
looks good to me :)
This is what i would do
CPU: AMD FX-6200 3.8GHz Six Core .................$134.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819106010
Mother Board: MSI 760GM-P34 .........................$69.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130657
RAM: G.Skill Ripjaws X Series 8GB (2 x 4GB) ...$49.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231445
Graphics Card: EVGA GTX 660Ti FTW 2GB ....$309.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130837
PSU: Corsair Builder Series CX600 600Watt ....$69.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139028
Case: Xion Gaming Series XON-560_BK ...........$39.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811208052
total: .................................................................$674.94
this is probably your best bang for your buck. it's far better than the one you link too. this processor and graphics card blow the doors off the ones in your link. And only get an optical drive if you actualy need one, most people never use them anymore and that money would be better spent on other things. hope this helps :)
Awesome thanks for the feed back =). So everything will fit in that case?
acording to all the info i can find on it, yes. but i've run into plenty of problems with cases because they don't always list all the importent info. but really a case is a case and it comes down to personal taste. there are alot of them out there. pick one you like in your price range. just make sure it suports micro ATX mother boards. This is another great choice if you want to spend a little more. http://www.newegg.com/Product/Product.aspx?Item=N82E16811146065
