$650 Noob Build, Need advice
Hello, I'm looking for advice for this build.
http://pcpartpicker.com/p/RAud
Makin this post short.
Thanks,
Samuroot1987
http://pcpartpicker.com/p/RBvK
I dont need 1TB i think i would prefer speed :P (No offense with the face) ive got 557 out of 686 left in this   A-I-O
the most inportant question, what you wanne do with it? ☺ cause at topic start build i see things i realy cant get the clue of.. why those 2 ssds? if you on such a tiny budget,, why a cpu cooler? use the stock one, dont waste money on after market coolers. why a athlon? take a Phenom II X4 965...
well i made this of it..
http://pcpartpicker.com/p/RCy1
Game, The 2 SSD's are for boot and storage. I dont need 1TB, CPU Cooler, Better temps.
40 GB ssd is totaly waste of money, and if i was on such a tight budget i wont waste money on a aftermarket cpu cooler in the first place, i would put that money into a better gpu...
but yeah thats just me ☺
I thought it was 60?
haha no the first SSd you choosed is realy a 40GB crosaire Force 40GB ssd, and thats realy a waste, cause eaven for windows updates drivers some programs its just to tight..
CPU: AMD Athlon II X4 645 3.1GHz Quad-Core Processor ($74.99 @ SuperBiiz)
CPU Cooler: Xigmatek Dark Knight II SD1283 Night Hawk Edition 89.5 CFM CPU Cooler ($49.99 @ Newegg)
Motherboard: ASRock 970 PRO3 ATX AM3+ Motherboard ($82.55 @ Newegg)
Memory: Kingston HyperX 8GB (2 x 4GB) DDR3-1600 Memory ($60.99 @ Amazon)
Storage: Corsair Force 40GB 2.5" Solid State Disk ($77.99 @ NCIX US)
Storage: Mushkin Chronos 180GB 2.5" Solid State Disk ($159.99 @ Newegg)
Video Card: Asus Radeon HD 5870 X2 4GB Video Card
Case: Fractal Design Arc Midi R2 (Black) ATX Mid Tower Case ($69.99 @ NCIX US)
Power Supply: Antec EarthWatts Green 500W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($64.73 @ Outlet PC)
Total: $641.22
yeah you have selected a 40GB crosair ssd and a Mushking 180GB ssd
then i realy would suggest just  take out that 40 gb and put thay money into a 7870 gpu realy, that was my point i wanted to make here ☺
Is a aresI Crossfre Possaple?
sry, i dont understand what you write up here..
http://pcpartpicker.com/p/RLdV
Honestly I would get a better GPU over a SSD, but you said you wanted speed, so this is what I have to offer. Nailed it at $650.
Couple extra bucks if you want to go 6-core http://pcpartpicker.com/p/ROBY
Is there a Ares I Crossfire?
get rid of the ssd they are useless when it come to storage. ive had my pc for 1 month and a half and already filled it with 650gb of 1tb.
This build does not include the cost of the 2 gpus do you allready have these video cards?
Becase if you dont thats going to add up to a lot  more than $650
Nope. Have no gpu So just get the 2 card in the areis and crossfire for the same.  And mcwopppersnaggy I dont need 1tb. i ahve 557 of 686 left on a retail A-I-O.
Well what you picked out dosent include video card(s)
[img]http://i.imgur.com/SQzw17i.png[/img]
what is your budget for a gameing pc?
The cheaper the better i would say 650-450
