$650 Gaming PC Build
Hey guys, came up with a Build for a friend and his limit is $650 at most and this is what I came up with. Any advice or something I should change but to stay in budget?
Case: Thermaltake V3 Black Edition Mid Tower Case - $44.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133094
Motherboard: BioStar TA75M FM1- AMDSocket A75 - $79.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138333
CPU: AMD A8-3870K Unlocked Llano 3.0 GHz Quad Core w/ AMD HD 6550 on Board Graphics - $109.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819106001
Heatsink: Cooler Master Hyper 212 (AMD FM1 Compatable) - $34.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
Thermal Paste: Arctic Silver - $9.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16835100007
GPU: ASUS AMD Raddon HD EAH 6670 1GB VRam (Crossfires w/ on Board Graphics) - $92.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121442
RAM: 2x AMD Entertainment Edition 4GB RAM DDR3 (8Gb total) - $45.98 total
http://www.newegg.com/Product/Product.aspx?Item=N82E16820103001
Storage: Seagate Barracuda 1TB 7200RPM - $79.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148840
CD Drive/Burner: ASUS 24x CD/DVD Reader/Writer - $19.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
Power Supply: CORSAIR Enthusiast Series 750W Bronze Cert. $109.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139021
        Total: $628.89
NOOOOOO!!!!
No what?
the entire thing, I didn't have time to elaborate, kinda busy, but you can get a rig like 5 times as powerful for that price
If you have time to post and tell me I'm wrong and don't have time to help me, then whats the point?
umm something more like this?
https://secure.newegg.com/WishList/MySavedWishDetail.aspx?ID=21114346
I'm sure gigabuster could kick my ass at this
Something with these options will be much much faster. http://pcpartpicker.com/p/gEdz
I was coming back in like 2-3 hours and it takes a good hour or two to fine tune a list
CPU
MoBo/RAM/SSD
GPU
PSU
Case  EMCNANF98
HDD
Optical
dual graphics has roughly the same amount of power as a 5770
http://www.anandtech.com/bench/Product/538?vs=543
its being compared to a low tier i3 while the one on the newegg is top tier and it is still beating it, down the road you want something better, well new MOBO and CPU and possibly ram with DDR4 around the corner if you go with the APU as its the best that platform has, with 1155, you still have the upper half of the range of CPUs to go to
http://www.anandtech.com/bench/Product/399?vs=289
20 bucks more and you can get a low end i5 like in fermans build
looking back, I never have been one to manage time wisely, or at all
nice build but  iwould save up and make it future proof
