I'm going to use this for gaming and coding... Also, I will be using Ubuntu so I'm in no need for an OS and I also have all the peripherals. And I will be running some VMs. Those extra cores are going to be used wisely :) What do you guys think of this build? Or Should I go Intel?
CPU: FX-8350 149 Euros
Motherboard: Gigabyte GA-970A-DS3P 69 Euros
RAM: G.Skill Ripjaws X DDR3 2133MHz CL9 8 GB 78.95 Euros
HD: WD Caviar Blue 1TB Sata 3 50.95 Euros
PSU: Cooler Master G700 700W 66 Euros
Case: Cooler Master K350 USB 3.0 35 Euros
GPU: Sapphire R9 280 Dual-X OC 3GB 179 Euros
Total Price: 627.95 Euros
