Seeking input from folks with first hand experience accomplishing 3600mhz, max 1.35v, on AORUS Master or boards with similar stats. I am fine with tuning with DRAM Calculator but the less the manual tuning, the better. I’m ok with paying more for the RAM that can accomplish this. I love the aesthetics of the G.Skill Royal.
My requirements:
Stability/errors: Absolutely critical that the config is 100% stable (match stability of sticks’ base config)
If you want 3600 and 16-16-16-39 or better then that limits your choice down to Samsung B-die ICs as nothing else will do a tRCD that low at that speed.
And Samsung B-die is rather heat sensitive so if you’re sure that you can keep them under 50°C all the time then you’re fine otherwise you may need to switch to a different one and take a little hit with timings like Micron Rev. E (Micron E-Die), which can go to 16-18-18-38 on 3600.
If you want Micron E-die and don’t care about price then find something from Crucial with the speed and timings you like.
