64 GB SSD ok for the system
hi,
is the ADATA XPG SX900 64 GB ok for the system
i only need like 30GB of space
thanks
Yes, it will work fine but keep in mind windows updates (if using windows) will at some point leave you needing more space. Once you taste the speed, You gonna want to have your most used programs running at speed. I would consider at least an 120 or greater.
I don't want to encourage you to spend more money than you have to, but you may be cutting it a bit fine with 64GB. My Windows 7 is currently taking up around 50GB of space, and that's with me not installing all updates. I think you'll be okay for a while if you're selective about updates, but further down the line you're going to need more space. So it's a question of spending the extra now, or going with the 64GB and possibly having to buy a new SSD and re-installing your OS later.
I don't know where you're from but if you're in the States, a 120GB Kingston SSD actually costs $10 less than the 64GB Adata on Amazon. I have this SSD and it's worked very nicely for me.
I have a 32GB in my laptop, windows 7 64 bit that I boot off of. It fits windwos just fine, and a few downloads temporarily, but NOTHING else. 64GB should be fine. Just run your CCLeaners and your Windows Disk Cleanup... and you will be just fine
I'm definitely  going with the 64GB thanks
