6300 or 8320
hi guys I'm in nz for gaming what cpu 6300 or 8320 the 6300 is a lot cheaper but i heard its the same as a i3 does it bottle neck but i have also heard its just under the 8320/50 will it matter between 8320 or 6300 for gaming is there a big difference i would rather get the 8320 and oc to 4ghz the same as 8350 for cheaper but is there a big difference between 6300 and 8320 like fps.
The 8320 is faster and more future proof and with mantle coming up I expect to see an even greater performance increase. But it all comes down to your graphics card, if it's a low-end graphics card you will not see any changes in performance, regardless of the cpu.
8320 hands down ($217NZD pbtech), I have zero complaints with the 8350.
What gpu did you end up getting man?
*edit* if you are planning on doing any overclocking, I would strongly recommend an aftermarket air cooling or a closed loop water cooling unit ($100-$200).
The stock cooler isn't up to par for O.C'ing.
I'm also debating on which processor to get between these two, I currently plan on pairing a 7950 with the processor.
I'm going to get all my parts in one but ill go with a 7950 and upgrade to a 7970 if i need to later on but i was thinking the 7870 but i think the 7950 is the better choice. but ill get a after maker cooler so i can max out the 7950 if not ill get a arctic cooler thingy.
ok ill check out the deal.
8320 all the way. 8350 is a waste of 30 dollars for a factory overclocked on the same unlocked processor that you can do yourself in a minute's time. Only reason for 6300 is limited budget but again it's only 30-40 bucks more to get to a 8320. AM3 isn't going anywhere fast so might as well get the top-of-the-line 8-cores anyway.
Thanks guys, I also had the same question
FX8320 indeed not realy much more to say.
8320.
Bottlenecking is only really noticeable when you pair something like an Athlon 760k with a 770.
Both are great processors. But if you have room in your budget to go with an 8320 (Seeing as you intend on getting a 7950, pretty sure you got room), then go for it.
yes and about a 7950 its a great gpu, but honnestly the interessting 7950 models the voltage unlocked one“s, are on the same price level as the R9-280X so if you can afford a $300 gpu, dear god go with a R9-280X.
This.
HIS, Sapphire and Gigabyte all make (IMO) some of the better cards cards (Thought gigabyte have a tendency to sell a few with unlocked voltage, then lock them.) I'm not 100% sure if HIS have a 280x available yet. but if they do. see if you can find one decently priced.
Sapphire have a Toxic 280x available, runs a little loud from what I've been told, so bear that in mind,
8320 > 6300 anyday!
you'll see a significant minimum fps boost with the 8320 as compared to 6300
