Which is better for a 360 mm long by 60mm wide radiator, nzxt phantom 630, vs Corsair 750d, vs Corsair 760t? The rad is going in the top. Thnx
750D 110%. Great case with loads of room for big rads.
i have the 750d with alphacool 360x60mm rad. corsair sp140 fans.
Its in the roof.
It was a very tight fit as my mobo has a heatsink at the top of the mobo that i think overhangs the mobo ever so slightly. But I got it to fit and all is well.
I like the design of the corsair cases too.
Sweet thx, where did you get the alphacool rad
Also can u do push pull?
