- Budget. How much are you willing to spend?630
- Where do you live (what country), and what currency do you use? USA-- dollar
- -Is there a retailer you prefer?no
- Do you need or already have peripherals? (this can add to costs) no
- What will you be using your future computer for? Gaming? Rendering? Mix of both? Or is this a home media PC? Gaming, Recording and Editing
- Do you overclock or want to get into overclocking? I dont know what this mean
- Do you plan on going for custom watercooling now, or in the future? what is this
- OS. Do you need a new one? I need a window 7
- Do you plan on Mining BTC either for yourself or Tek Syndicate? What is this
If you Game-
- What kind of settings do you like or what FPS do you want to play at? atleast playing in medium setting or high
- What resolution will you be playing at? //or would like to play at. 1080p
- What kind of games do you like to play? Shooter, Strategy, and puzzle
- What specific game will you be playing (if applicable) Team Fortress 2, half life 2, garry mod, counter strike global offensive, mount and blade, civlization 5,
If you Render or Edit things-
- What application do you use to render? (very important) im not sure any tips for good app?
- Do you render movies or photshop pictures no
If you don't have peripherals -
- What kind of keyboard do you prefer? Mechanical, scissor, membrane, etc. i Have no preference
- What type of mouse-grip do you have? Palm, claw, combination? Palm
- what kind of games do you play? (mmo vs fps, for button management) i play more fps games
- What size monitor are you looking for, and what resolution? Screen type (IPS, S-IPS, TN, etc.), hertz (60, 120, etc.) i dont want a huge moniter like a small to medium size screen and i want the resolution to be 1080pp
