600$ rig for starcraft 2
my frend waunt a gaiming pc to play starcraft 2 in stacraft 2 usualy the battle end up whit 200 vs 200 units so he need a strong cpu but a cheap cpu that could run 200 vs 200 units on screen so im thinking ether a apu the a10 5800k or a amd 965be any surgestion for a build also i live in canada so it a bit more expesive here for pc part anyway i can only shop online at newegg.ca or ncix.ca any sugestion
FX 8350 should do a great job for your cpu
8350 for a $600 build are you seriousss mannnnnn
Try this, $600 is around the price point where youd want a 965 and a 7870
http://pcpartpicker.com/p/BJeW
I left the case out of the build because I'd imagine you'd want to pick out a case yourself
http://pcpartpicker.com/p/BJsk
650. Is a great little gaming machine, just needs some HDD space and an aftermarket cooler in the future.
And an OS/HDD
yOU GUYS ARE DOING IT WRONG
http://pcpartpicker.com/p/BKUf
sry oxy but i must shame the
http://pcpartpicker.com/p/BElW
just add HDD and optical if required
0.0 wat.
I will agree that ram is cheaper
http://pcpartpicker.com/p/BLjh
here is a better build with an even faster Video card then my original one
http://pcpartpicker.com/p/BOZl
