$600 PC - Ordering Tomorrow
Since I'm ordering this computer tomorrow, I wanted to make sure that it works. Will it?
http://pcpartpicker.com/p/CrDv
Geez, that haf is a pretty good deal. You could probably find a 2Gb 7850, XFX and HIS always have pretty nice deals on em. If you can find a source 210, 210 elite, or 220, I'd do that though.
Thats a pretty good build for the money though, yeah it'll work!
I say this to everyone who wants to buy a HAF, please don't. As an owner of a 932, i'm telling you these cases are way out of date and require a lot of after market modifications to function at a level similar to modern cases (Quiet fans, filters, mobo tray modding, interior painting) it's a pain and you can do much better with a $50 nzxt,antec,corsair,zalman case.
First of all, trah your 932 then -_-
Also, I'm not buying a 932, buying a 912. I've done my research, my friend even has one and loves it.
*trash
932= Bigger more fully featured 912. Feel free to buy it, but the monthly cleaning and annoyingly loud case fans will start to wear on you. Also just wait untill you want to mount a coolers backplate. that's the definition of fun.
I have a pretty identical build, it costs a bit more though. You can tone down some things, but I do recommend the 7870 ghz edition from HIS because of the cooling.
http://pcpartpicker.com/p/CbG5
If you're not planning on overclocking, well just take away the cooler. But the cpu isnt a black edition for nothing, it's basically built for overclocking. For the money the CM hyper 212 evo is king.
