$600 PC Build?
So I don't know much about computers and I came here before but my budget changed a bit :\
Price - $600 - $640 (That's all I have)
Use - Gaming
Games - Nothing like BF3 but I play alot of games but taking the highest spec games I have would be LA Noire, Red Faction:A, SR3, and a few others. So maybe it can play most modern games on Med - High possibly?
Programs - Possibly some recording
Overclocking = No
No SSD
Need Monitor
If possible can the parts be all from Newegg? Maybe the exception of 1 item but yeah...
Happy Holidays.
I would get a cheap amd athlon ii x4 (or simular) and get a good amd gpu, due to the reasent price drops. I live in europe, so I can't really give you links, but that should get you going. always remember newer to buy no name stuff. espessialy with psus. nothing bu horror stories there.
Happy Holidays to you to ;)
i5 2500k and a XFX 7850 are prettyin exspensive right now, plus they'll smoke those games at Ultra settings. Hope this helps.
Final Build: $616.93 (that includes shipping)
I did this in about 10 minutes so It isn't great but I'm sure with a bit of feedback we can fine tune it and maybe lower the price.
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813157291
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103996
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820148654
Graphics Card: http://www.newegg.com/Product/Product.aspx?Item=N82E16814161405
HD: http://www.newegg.com/Product/Product.aspx?Item=N82E16822136939
Power Supply: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811352020
If you have a spare HD lying around (maybe from your current build?) then you can take that out and use that instead, maybe even get yourself an SSD for the boot drive and some applications and keep the other drive for storage.
Thanks for the tips and suggenstions. I like the build someone suggested but was wondering about this one
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=21271412
I could just pick out a monitor and case but spec wise I'm still not sure =\
That build is absolutely fine, the only thing I would change really is spend a bit more cash and go with a piledriver cpu (maybe the fx-6300?). I would also grab an HD 7850 personally because it is a good card and it is really cheap (it also out performs the gtx 650 http://www.hwcompare.com/13466/geforce-gtx-650-vs-radeon-hd-7850/).
If you went with that build though you would be perfectly fine.
PCPartPicker part list: http://pcpartpicker.com/p/uiRT
Price breakdown by merchant: http://pcpartpicker.com/p/uiRT/by_merchant/
Benchmarks: http://pcpartpicker.com/p/uiRT/benchmarks/
CPU: AMD Phenom II X4 955 Black 3.2GHz Quad-Core Processor ($94.99 @ Newegg)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($34.99 @ Newegg)
Motherboard: ASRock 970 EXTREME4 ATX AM3+ Motherboard ($97.87 @ Newegg)
Memory: Samsung 4GB (1 x 4GB) DDR3-1600 Memory ($19.99 @ Newegg)
Storage: Western Digital Caviar Blue 500GB 3.5" 7200RPM Internal Hard Drive ($54.99 @ Newegg)
Video Card: PowerColor Radeon HD 6770 1GB Video Card ($106.97 @ Newegg)
Case: NZXT Source 210 Elite (Black) ATX Mid Tower Case ($57.98 @ Newegg)
Power Supply: Corsair Builder 500W 80 PLUS Bronze Certified ATX12V Power Supply ($39.99 @ Newegg)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($22.98 @ Newegg)
Monitor: Acer V183HV Ab 60Hz 18.5" Monitor ($98.98 @ Newegg)
Total: $629.73
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2012-12-26 18:26 EST-0500)
