I'm looking to build a PC in a bitfenix prodigy thats ships to Norway, as I am living there at the moment. I want to get a haswell system because the advantages it has but I only have $600 to spend on the pc (including the Operating System). Does anyone know any sites that ship to Norway for less than $50?
If you are looking at gaming or similar things, i'm sorry to tell you but $600 isn't a great budget. If at all possible, save a little more for $800 and your options have increased tenfold.
not necesarily, i got a nice build for 550. scratch the case (its a money hole) go with a nzxt gamma classic (or anyother 40 buck case, it has to be atx though). Next go with a phenom iix4 965 be, a sapphire hd 7850 1 gb. The reason u should go with amd is cuz the new consoles will have amd which means u will be better optimised for games. Then go with corsair vengeance ram 8gb 1600mhz, wd caviar blue 1tb hdd, a cx500w. Lastly if there is money left over, i would get a nice cpu cooler (make a new thread for tht if u have to). Well good luck!
