600$ pc build, need help?
Hey guys hows it going? So my friend bought the Alienware X51 and wanted me to get into PC gaming with him.  I was an avid PC gamer back in the day (Anyone remember cs 1.6?) but now i've just been casually on the 360 nowadays.  Anywho, i saved up about 600$ over the summer and i'm looking to buy the best possible build for the money.  I'm not expecting to max out crysis 3 because even top of the line GPU's struggle with that game.  But if it can run BF3 on high settings without a struggle, then i'm totally satisfied.  I've been looking around for a while and this is what i think is decent for the amount of money, don't be afraid to criticize and correct anything that can be improved, i'm not an expert! If you reccommend anything over another let me know! thanks in advance.
CPU: AMD Athlon X4 750k (85$)
GPU: EVGA GTX 650 ti Boost (175$)
Ram: G SKILL Ripjaws Series 8 gb 2x4 1333 DDR3 (62$)
Motherboard:  GIGABYTE GA-78LMT-S2P AMD 760 Motherbaord Micro ATX (60$)
PSU: Corsair Cx430 watt (40$)
HDD: Seagate Barracuda 500gb (60$)
Case:  Coolermaster HAF series ATX Midtower (60$)
Any Suggestions? Thanks!
http://pcpartpicker.com/user/Killerfrenzy96/saved/2g6H
This, just lower the quality of ram to a cheaper 2 x 4 1600 brand and a 500 watt psu if you can't go over 600.
http://pcpartpicker.com/p/1wGFz
Better MB for future overclocking, less expensive ram, less expensive case (and a little more flashy to compete with your friends overly expensive alienware), more suitably sized and better quality PSU (The CM PSU has really bad noise and ripple levels).
http://pcpartpicker.com/p/1wTrF
$610 out the door.  The $30 rebate on the PSU will take the cost down to $580.  I'd higly reccomend getting a cpu cooler if you can spend a bit more money (hyper 212 evo and xigmatek dark night hawk II are both good fairly inexspensive options), but one can be added easily further on down the line.
Please don't get that PSU.
http://www.hardwaresecrets.com/article/Cooler-Master-GX-750-W-Power-Supply-Review/917/7
