$600 gaming PC build
http://ca.pcpartpicker.com/user/Skreedles/saved/3xx4
After doing some research I came up with this build how does it look?
From where I will be getting it it will turn out to be $600.
Good Start, Something like this would be good:
http://ca.pcpartpicker.com/p/2Hmyd
Dual Channel Memory instead of one 8gb stick.
Added A CPU Cooler that's a bit better than the stock one (Didn't spring for the hyper 212 evo though)
Different Model of 270, this is preference though the asus was fine.
And yeah that's about it. price is around 670, if you want to get around 600/sub 600 you'll probably need to go athlon but this build will be quite capable
+1
Is the power supply big enough?
Yep.
Will this need a 430 or 500 psu? Should I get the asus mobo or asrock? the asrock is on a huge sale right now?
A 430w PSU is plenty for this build.
I would get the Asus M5A97 R2.0.  The ASrock has somewhat weak VRMs compared the the M5A97 R2.0.
Is that a good case?
http://ca.pcpartpicker.com/part/thermaltake-case-vl80001w2z ?
It's an alright budget case.  It's budget.  It'll work with your components, but nothing absolutely spectacular when compared to $100+ cases.
well its a nice case for its price
there is a very nice red / black version of this case with usb 3.0.
http://www.newegg.ca/Product/Product.aspx?Item=N82E16811133200
