How did I do? I plan on ordering the parts around the new year.
What else could I do?
EDIT: http://pcpartpicker.com/p/tNBz my bad guys!
Ehh.... where are the parts?
repost your parts list or link from your list
Btw, Teabag with the AMD Phenom II X4 965BE and ASrock 970 Extreme3 you can overclock the CPU to 4.3Ghz (That's how far I got Without changing the voltage) Because I saw you yesterday aswell on my post about the overclocking and I just wanted to let you know.
okay maybe ill do that and cut down on the gpu?
Can you show the parts that you have now? I think something went wrong because I can't see them
Do you want to overclock? Otherwise it looks great!
sure http://pcpartpicker.com/p/tNBz they should be in the origninal post too i edited them in
my plan was to overclock in the future i need to get all the basic parts first then ill invest in an aftermarket heatsink. I still have to buy the moniter and OS
Looks similair to my build only one thing different: I have a HD7950, And it works perfect so that of you schould work great aswell!
Okay sweet! thanks for the input!
Good luck with building! Let me now how it went, I'm curious :D
