As it says in the title I need a $600 Gaming Build but i plan on buying it around Christmas time
A few requirements and such for this budget:
- A monitor
- A keyboard (I dont care if it is a 5$ keyboard as long as it works)
- I have a power supply already from somewhere i dont remember lol so i dont need a PSU (Thermaltake TR2 600w)
- Id prefer mATX or mITX but if i have to ill go towards ATX.
- I dont care about the case as long as it isnt held together by gum and sticks.
- Wi-Fi card.
I currently run of a "Easy Bake Oven" laptop that runs at 190 Fahrenheit (Asus X54C w/ 8gb of ram)
Thank you and please leave pc part picker links :)
-MaTriix
I tried to make a small form factor build(seemed like what you were shooting for. I went over a bit, after MIRs.
http://pcpartpicker.com/p/1ZVI8
CPU: AMD Athlon II X4 760K 3.8GHz Quad-Core Processor. Pretty decent CPU for the price.
MOBO: Gigabyte GA-F2A85XN-WIFI Mini ITX FM2 Motherboard. Good motherboard with WiFi.
RAM: Crucial Ballistix Sport 8GB (2 x 4GB) DDR3-1600 Memory. Typical memory.
HDD: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive. Your normal storage drive. If you can find a SATA hard drive you can salvage, you can save this an upgrade the GPU to a HD 7870 or something.
GPU: MSI Radeon HD 7850 2GB Video Card. Still a great card for 1080p.
Case: Cooler Master Elite 120 Advanced (Black) Mini ITX Tower Case. Great budget case for the price.
Monitor: Acer G226HQLBbd 60Hz 21.5" Monitor. Cheap monitor, but it should work.
Keyboard: Microsoft Keyboard 200 Wired Standard Keyboard. 8 dollar cheapy keyboard.
This is a good GPU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131484&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
Could i cannibalize my current laptop drive (Just a 5400rpm 320gb drive) and get like a Sapphire 7870
Yeah, you could do that.
http://pcpartpicker.com/p/1ZXoD
This is what i have came up with and i would be cannibalizing my laptop drive and then replace it with a 1tb drive later on http://pcpartpicker.com/p/1ZXK3
And would my processor come with a cpu cooler or would i have to get a aftermarket one
If i did get a aftermarket cooler could i get a decent overclock on my processor and could i overclock my graphics card by chance?
Im also concerned by no L3 Cache on this cpu. Is it important?
Newegg had crap reviews on that RAM, so I went with the next decent branded kit. Just a heads up.
The processor will come with a cooler, but it's only meant for stock speeds really. If you want to overclock, I would go with a different case, like the Fractal Design Node 304 and a H60.
You can overclock your graphics card pretty easily by using a program called MSI Afterburner, or Sapphire Trixx.
Having no L3 cache won't really hurt the CPU, as I believe AMD has increased the cache in L1 and L2.
Okay well I have this http://pcpartpicker.com/p/208xd
I dont know what i want to do for a case should i just get a black prodigy? or something else
http://pcpartpicker.com/p/209hW
buy this ram now. amazing high quality ram on sale. 2400mhz cas 10. just get it now!
cpu is really good. much better than a ahtlon x4 cpu.
mobo is not the best. a 990fx board is better but 970 will do. crossfire is better on a 990fx and oc is also better on a 990fx board. have 0 experience with this mobo
ram is amazing.
500gb is enough. you can upgrade to a 1tb an it will be 3$ over your budget.
corsair 200r is good. gpu fits and build quality is good. solid case on sale. great reviews.
psu. 600watt is enough and you have room for a other gpu or upgrade to a fx 8350 or oc the fx 6300 with a 30$ cpu cooler like a t40. sapphire recommend a 600watt psu for crossfire 7870.
7870 is a 270x but a lot cheaper. it runs games pretty good. expect awesome performance with mantle.
Need Small form factor this thing is gonna be moved around a bit so id prefer a small form factor
I personally hate the prodigy. It's big, rocky, and expensive :P. I have this case:
http://pcpartpicker.com/part/fractal-design-case-fdcanode304bl
These go on sale pretty often for around 55 bucks. If it goes on sale, snatch it up. It's small, quiet, modular, and quite high quality.
